AAcannot boot a kernel with kexec
Added by aggelis aggelis over 7 years ago
I use MitySOM-5CSX dev kit and i would like to boot to a different kernel using kexec.
In my configuration:
KERNEL : https://github.com/altera-opensource/linux-socfpga/archive/socfpga-4.9.76-ltsi-rt.zip
COMPILER : https://releases.linaro.org/archive/14.04/components/toolchain/binaries/gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux.tar.bz2
In the kernel configuration kexec is enabled
zcat /proc/config.gz |grep KEXEC CONFIG_KEXEC_CORE=y CONFIG_KEXEC=y
and the default kernel cmdline is
# cat /proc/cmdline root=/dev/mmcblk0p3 rootwait rw earlycon
First the kernel is loaded with :
# kexec -d -l zImagebkx --dtb=socfpga_cyclone5_mitysom5csx_devkit.dtb --command-line="root=/dev/mmcblk0p3 rw rootwait earlycon" kernel: 0xb69a8008 kernel_size: 0x4a55c8 MEMORY RANGES 0000000000000000-000000003fffffff (0) zImage header: 0x016f2818 0x00000000 0x004a55c8 zImage size 0x4a55c8, file size 0x4a55c8 kexec_load: entry = 0x8000 flags = 0x280000 nr_segments = 2 segment[0].buf = 0xb69a8008 segment[0].bufsz = 0x4a55c8 segment[0].mem = 0x8000 segment[0].memsz = 0x4a6000 segment[1].buf = 0x48fb0 segment[1].bufsz = 0x7cf4 segment[1].mem = 0x1744000 segment[1].memsz = 0x8000
and then try to start new kernel
root@node1:~/kernels/kexec_base_kern/newroot/boot# kexec -d -e [ 1047.666926] kexec_core: Starting new kernel [ 1047.671121] Disabling non-boot CPUs ... [ 1047.728309] CPU1: shutdown [ 1047.731981] Bye!
And then nothing. Finally after a while the board reboots automatically to U-boot
the kexec version used is
root@node1:~# kexec --version kexec-tools 2.0.14
The above kernel boots normally with uboot and i can see output in ttyS0.
