SSHDMI Output and Quartus Versions
Added by Stephen Snyder over 10 years ago
I noticed that the HDMI Output example you've posted was done in Quartus 15.1 but the VM with the toolchain installed is still on Quartus 14.x. What would you recommend for someone deriving a project from the HDMI example? Should we upgrade the Quartus version on the VM, install Quartus 15.1 on a separate machine and use the VM for software development, or build the project in 14.x?
Steve
AB RE: HDMI Output and Quartus Versions - Added by Alexander Block over 10 years ago
Steve,
We have successfully rebuilt the HDMI example using Quartus 14.1 however you will require a license to support the VIP Suite (Video and Image Processing Suite MegaCore Functions).
You can find out information about licensing from this page: https://www.altera.com/products/intellectual-property/ip/dsp/m-alt-vipsuite.html
Thank you,
Alex
