AHDSPLink kernel driver
Added by Andrew Holt about 15 years ago
I have built dsplinkk.ko using the instructions on the wiki. Modinfo reports:
modinfo dsplinkk.ko
filename: dsplinkk.ko
license: GPL v2
depends:
vermagic: 2.6.34-rc1-00093-g3e8f54f-dirty preempt mod_unload modversions ARMv5
And, on my MityDSPL138 uname -r reports:
So I copy the file on the the board, and
insmod: error inserting 'dsplinkk.ko': -1 Unknown symbol in module
dsplinkk: Unknown symbol __bswapsi2
Any ideas ?
MW RE: DSPLink kernel driver - Added by Michael Williamson about 15 years ago
Hmm...
Are you using the same build of the kernel (e.g., the same .config file) as the one that is running?
Did you use the same toolchain for both builds?
I haven't seen this particular issue. Can you post your .config file that I might try to reproduce?
AH RE: DSPLink kernel driver - Added by Andrew Holt about 15 years ago
I have just rebuilt the kernel module, and I have just spotted that the build issues a warning:
Building kernel side code using kbuild
make PROFILE=RELEASE -C /home/mitydsp/MDK_current/sw/ARM/linux/linux-davinci SUBDIRS=/home/mitydsp/MDK_2011-03-31/sw/3rdparty/dsplink_linux_1_65_00_03/dsplink/gpp/src ARCH=arm modules
WARNING: "__bswapsi2" [/home/mitydsp/MDK_2011-03-31/sw/3rdparty/dsplink_linux_1_65_00_03/dsplink/gpp/src/dsplinkk.ko] undefined!
Kernel side build complete
Copying dsplinkk.ko to /home/mitydsp/MDK_current/sw/3rdparty/dsplink_linux_1_65_00_03/dsplink/gpp/export/BIN/Linux/OMAPL138/RELEASE
In answer your your questions:
Yes.
Yes.
And .config is attached.
Andrew
config (45.5 KB) config
Are you passing the CROSS_COMPILE=arm-angstrom-linux-gnueabi- declaration to the make as well?
    (1-3/3)
