MLAM1808-industrilal I/O performance
Added by Mads Olav le Maire almost 14 years ago
I am currently testing network performance. Having installed the netperf utility in my root file system, I am able to test performance between my development machine and the Industrial i/O card.
Running netperf, measuring network throughput in megabits (TCP stream test) and load on both sender and receiver gives me the following results:
Operation Throughput Util. Send local Util. Recv remote
Local loopback 140.32 mb 99.90% 99.90%
Local IP 177.39 mb 99.90% 99.90%
Remote machine 65.04 mb 99.90% 0.36%
In the last case it seems that the AM1808 is reaching its limit when it comes to computing power before the bandwidth of the network sets the limit. I think the processor is running on 300 Mhz clock frequency. Although the 2.6.34 kernel reports switching to a higher clock frequency during startup, (The 3.2 kernel does not) I see no values above 300 Mhz when I inspect /sys/kernel/debug/davinci_clocks.
Is there a way that I can speed up the clock frequency? Any particular isssues I should be aware of?
regards
Mads-l
Replies (10)
MW RE: AM1808-industrilal I/O performance - Added by Michael Williamson almost 14 years ago
Hi Mads-l,
Can you print out the factory configuration information? Certain modules (Revision "A" silicon, IT silicon and lower speed grade options) do not support frequencies above 300 MHz (rev A silicon, 375 for IT silicon) and they are limited during the kernel boot up. You should be able to see some messages to this affect in the bootlog (dmesg | grep -i speed).
It the factory configuration information is corrupted, the kernel defaults to a "safe" 300 MHz speed limitation.
ML RE: AM1808-industrilal I/O performance - Added by Mads Olav le Maire over 13 years ago
Here is some information - cannot get any useful information from the bootlog.
From Bootloader startup:
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
EMIFA CLock : 100000000 Hz
DSP Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config : 2
MMC 0 Enable : 1
Resetting ethernet phy
Net: Ethernet PHY: GENERIC @ 0x03 [0x8]
Bootloader config:
U-Boot > config
MityDSP-L138 Configuration:
Config Version : 1.0
Config Size : 264
Manufacturer : Critical Link
Ethernet Config : 2
Ethernet Name : GENERIC @ 0x03
Ethernet PHYMask: 8
LCD Config : 0
MMC0 Config : 1
MMC1 Config : 0
U-Boot config set:
U-Boot > config set
Ethernet Config : 2
UART - 0 Configuration ---
Enable UART : 0
UART - 1 Configuration ---
Enable UART : 1
Baud : 115200
HW Flow Control : 0
Is Console : 1
UART - 2 Configuration ---
Enable UART : 0
SPI - 0 Configuration ---
Enable SPI : 0
SPI - 1 Configuration ---
Enable SPI : 1
CLK is Output : 1
Chip Select [0] Enable : 01
Chip Select [1] Enable : 00
Chip Select [2] Enable : 00
Chip Select [3] Enable : 00
Chip Select [4] Enable : 00
Chip Select [5] Enable : 00
Chip Select [6] Enable : 00
Chip Select [7] Enable : 00
ENA ENable : 0
CLK Rate : 300000000
LCD Configuration
LCD Enable : 0
MMC 0 Configuration
MMC 0 Enable : 1
Write Protect Pin bank : 4
Write Protect Pin bank offset : 1
Card Detect Pin bank : 4
Card Detect Pin bank offset : 0
From Linux:
root@am180x-evm:/# cat /proc/cpuinfo
Processor : ARM926EJ-S rev 5 (v5l)
BogoMIPS : 148.88
Features : swp half thumb fastmult edsp java
CPU implementer : 0x41
CPU architecture: 5TEJ
CPU variant : 0x0
CPU part : 0x926
CPU revision : 5
Hardware : MityDSP-L138/MityARM-1808
Revision : 0000
Serial : 000000000001adb9
MW RE: AM1808-industrilal I/O performance - Added by Michael Williamson over 13 years ago
In u-boot, run the command "factoryconfig".
This is the "factoryconfig" printout:
U-Boot > factoryconfig
Factory Configuration:
Config Version : 1.1
MAC Address : 00:50:C2:BF:8B:D2
Serial Number : 110009
FPGA Type : 0 [none]
Part Number : 1808-FX-225-RC
U-Boot >
What version of the kernel are you using? The pre-programmed one on FLASH? That version of the kernel may be older than the patch that adds support for upping the speed beyond 300 MHz.
Can you do a "dmesg" and dump the log file?
Sorry for the inconvenience.
I am usually running the 3.1.x kernel that I build from the git repository downloaded from Critical link. Here are kernel logs for both this kernel and the kernel which resides in SPI-flash from factory.
I notice that the /sys/kernel/debug/davinchi_clocks seems to report the same same. (ref_clk 24 MHz pll0 300 MHz)
mads-l
dmsg2_6_34.txt.log (8.85 KB) dmsg2_6_34.txt.log Kernel log pre-installed image
dmsg3_1_x.txt.log (10.7 KB) dmsg3_1_x.txt.log Kernel built from git repository
Can you check if CONFIG_CPU_FREQ=y is set in the 3.1 kernel configuration. Also can you confirm that the CONFIG_CPU_FREQ_GOV_USERSPACE=y?
can you also:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
The sys/kernel/debug/davinci_clocks will only tell you the current settings, not the options...
Yes - both kernel settings is set to 'y'.
root@vdr:/sys/devices/system/cpu/cpu0/cpufreq# cat scaling_available_frequencies
456000 408000 372000 300000 200000 96000
Mads-l
Oh. You should be all set, see Setting_CPU_Speed.
Missed that one - it's working.
Mads-l
    (1-10/10)
