CBMItyDSP L138-FI-236-RL Industrial IO Board 80-000268RI-2 rev. B, wont reset and no output on serial port.
Added by Christopher Brunson over 13 years ago
I am trying to load the hello world program.
So I set up the serial port on my pc with the following settings:
Baud Rate = 115200
Data = 8 bit
Parity = none
Stop = 1 bit
Flow Control = none
I also connected the provided null modem cable.
When I power the IO board the power good LED lights up and then nothing happens on the serial port.
Pressing the reset button does nothing.
I was wondering if anyone had come across this problem before and come up with a solution?
Thanks.
Replies (7)
BD RE: MItyDSP L138-FI-236-RL Industrial IO Board 80-000268RI-2 rev. B, wont reset and no output on serial port. - Added by Bob Duke about 13 years ago
Hello Christopher,
What terminal program are you using to connect to the serial port on your PC?
-Bob
CB RE: MItyDSP L138-FI-236-RL Industrial IO Board 80-000268RI-2 rev. B, wont reset and no output on serial port. - Added by Christopher Brunson about 13 years ago
Hi Bob,
I have been trying with both screen and putty.
Both seem to work fine when I loopback the tx and rx lines on the serial port.
Chris.
JC RE: MItyDSP L138-FI-236-RL Industrial IO Board 80-000268RI-2 rev. B, wont reset and no output on serial port. - Added by Jonathan Cormier about 13 years ago
Chris,
Have you tried to add another null modem adapter into the mix or a straight-thru cable just as a sanity check.
-Jonathan
Swapping up the cables sees to make no difference, and if I plug in my work PC into the supplied cross over cable I get an IP.
Chris.
I finally got it working by directly connecting the serial port to the board.
Thanks for the help,
Chris.
TI RE: MItyDSP L138-FI-236-RL Industrial IO Board 80-000268RI-2 rev. B, wont reset and no output on serial port. - Added by Tim Iskander about 13 years ago
Chris,
Glad to hear of your success... if you don't mind, can you detail your setup a bit. Are you using a USB serial adapter (if so which one) or a serial port on your PC motherboard or pci card?
It sounds like the serial port you are using has been set up as a DCE instead of the usual DTE.
cheers
/Tim
I am using a nondescript USB to RS232 cable, dmesg tells me its a FTDI USB-RS232 cable, with a FT232RL onboard.
Chris.
    (1-7/7)
