CRSPI1_SCS0 -> Edgeconnector pin 53?
Added by Christian Rückl about 14 years ago
is the pin 53 on the edgeconnector (L138-Module) connected with the E19-pin (SPI1_SCS0) on the OMAP processor?
thanks,
Christian
MW RE: SPI1_SCS0 -> Edgeconnector pin 53? - Added by Michael Williamson about 14 years ago
Yes,
However, this pin should normally be treated as RESERVED as it is the chip select line for the on-board SPI NOR FLASH. The NOR FLASH is used as the primary first and second stage boot loader media by the OMAP-L138.
This pin was brought out to the edge connector in order to facilitate factory configuration and test.
