Virtual Box aborts
Added by Thomas Catalino about 14 years ago
I have installed the “mityarm-335x_SDK.ovf” on to the Linux machine with the help of VM Virtual box software and started running the same.
While trying to compile the kernel located at “Home/projects/linux-mityarm-335x”, connection to Virtual box is getting aborted and in turn the compilation process. Even simple tar command to compress kernel also creating the same problem.
I have changed the settings to avoid screen saver and display turn off in case it has an effect.
Could you please let me know any further settings need to be done?
RE: Virtual Box aborts - Added by Tim Iskander about 14 years ago
Check that the correct version virtualbox guest additions are installed in the VM (the one that is included would most likely be for an older version) and that the virtualbox extension pack is installed in the VirtualBox app itself.
The guest additions can be installed using the Devices menu in the VirtualBox session window.
The extension pack is available for download from www.virtualbox.org
Is the host machine running linux too? What are the details on the host PC?
cheers
/Tim
RE: Virtual Box aborts - Added by Raja Vankam about 14 years ago
Host machine is running on Ubuntu 10.04. I have downloaded the extensions properly and able to run the virtual machine.
I figured out it as a problem with memory allocated to virtual box and after adjusting it problem of aborting is solved.
Regards,
Raj.
