Reg. ethernet Transciever
Added by ABDUL SALAM almost 14 years ago
In MityArm 3359 carrier Board has been used one VSC8601 ethernet ic, but it will not support for the industrial temperature range,So could you please suggest one RGMII Tranciever with same pin to pin compatibility( VSC8601).
Kindly reply ASAP.
Regards
Salam
RE: Reg. ethernet Transciever - Added by Alexei Shkurko over 13 years ago
Hi Salam,
the VSC8601 is a unique Vitesse part and has no IT range drop in replacements in same package with same pin-out.
Regards,
Alexei
