CLRTC Crystal Specifications
Added by Chris Leon about 12 years ago
What are the ppm drift specifications for the TPS65910 RTC crystal?
JC RE: RTC Crystal Specifications - Added by Jonathan Cormier about 12 years ago
For the 32khz crystal attached between the OSC32KOUT and OSC32KIN pins, according to its datasheet, the frequency tolerance at 25C is +-10ppm.
CL RE: RTC Crystal Specifications - Added by Chris Leon about 12 years ago
Great, thank you for the information. Is it a similar specification for the other oscillator on the board, connected to the ARM?
Theres a 24MHz crystal between XTALOUT and XTALIN on the ARM. Its frequency tolerance at 25C is +/- 25ppm.
Note these numbers are based on a 3359-GX-226-RL RevD.
    (1-3/3)
