Moving rbf file from host to dev-board
Added by Rich Bagdazian about 11 years ago
I have created a new rbf file with some custom logic added which I built using QSYS,
and converted from SOF format to RBF format as required.
I attempted to use an ftp client (Filezilla) to move the rbf file to the dev board
and the connection is rejected in both regular and sftp modes. Is there something
I need to do to use ftp or ssh to move files back and forth?
Thanks!
Rich
RE: Moving rbf file from host to dev-board - Added by Daniel Vincelette about 11 years ago
Hi Rich,
You'll need to SCP the RBF over, I'm pretty sure FTP wasn't enabled by default. But I believe you will need to set a root password on your board in order to SCP files to it.
To set a root password use the passwd command on the 5CSX.
Dan
