Xubuntu VM corrupt zip error
Added by John Meier almost 10 years ago
I recently received my MitySOM_5CSE and was surprised that there was a virtual machine image to get started on development. Amazing!
When I followed the instructions in readme.pdf I received an error while importing the OVA file:
Could not create the imported medium 'C:\Users\xxxxxxx\VirtualBox VMs\xubuntu64_1404_MitySOM_5CSx_dev_vm\xubuntu64_1404_MitySOM_5CSx_dev_vm-disk1.vmdk'.
VMDK: Compressed image is corrupted 'C:\Users\xxxxxxx\xubuntu64_1404_MitySOM_5CSx_dev_vm-disk1.vmdk' (VERR_ZIP_CORRUPTED).
Result Code:
VBOX_E_FILE_ERROR (0x80BB0004)
Component:
ApplianceWrap
Interface:
IAppliance {8398f026-4add-4474-5bc3-2f9f2140b23e}
[Screenshot attached]
Here's the file hashes, same on USB and local disk:
File: xubuntu64_MitySOM_5CSx_dev_vm.ova
CRC-32: 2a089302
MD4: 1a84fc2664750e80cb8b4bac7a1846e5
MD5: c8ea177084cd358892087fb58088aaf2
SHA-1: db13ae7bc40aeed4ff1907d1714fc824b858f3ad
Replies (4)
RE: Xubuntu VM corrupt zip error - Added by John Meier over 9 years ago
I'm using VirtualBox w/ extension pack 5.0.14r105127
I bought three of these MitySOMs and all three copies of the OVA have the same hash and all fail with the same error, so at least it's consistent.
I'd appreciate it if CriticalLink would confirm that the file I have is the same and if the symptoms match to determine if there's a corrupted VM image or if a modified import procedure can fix this.
RE: Xubuntu VM corrupt zip error - Added by Alexander Block over 9 years ago
John,
Sorry about the delay in getting back to you. We have received your e-mail as well.
As you have found it appears that a number of the USB drives were copied with a corrupt .ova file and were not caught prior to shipment. We've improved our process to perform additional checks but prior stock did not get updated.
The latest version of the VM can be found from a link on this wiki page (https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/Linux_Build_Virtual_Machine). By downloading the latest .ova file directly from there your issues should be resolved.
Of course let us know if you still are having problems and we can look into it further.
Alex
John,
Thank you for updating us on this, happy to hear you're up and running.
Keep in mind that we have additional information about this module fmaily/development kit on this wiki page (https://support.criticallink.com/redmine/projects/5csxbase/wiki).
Alex
    (1-4/4)
