Second PHY MDIO interface
Added by V J almost 6 years ago
Hi
I have added a second PHY to my board and connected it through the FPGA IO. I am using HPS EMAC0 and have added the emac splitter and the gmii_to_rgmii adapter in QSYS.
My problem is the MDIO interface. Connecting SignalTap to the MDIO and MDC interface I can see that the request from the Linux driver is correct, the PHY responds correctly and correct value is written to the mdi input to the splitter, but the linux driver only reads zero. I have used memtool as well, writing/reading directly to the PHY (address 0xFF700010 and 0xFF700014) and I see the same behavior: The GMII_Data Fields at address 0xFF700014 is not updated.
My dts changes for the second PHY:
gmac0: ethernet@ff700000 { compatible = "altr,socfpga-stmmac", "snps,dwmac-3.70a", "snps,dwmac"; altr,sysmgr-syscon = <&sysmgr 0x60 0>; reg = <0xff700000 0x2000>; interrupts = <0 115 4>; interrupt-names = "macirq"; mac-address = [00 00 00 00 00 00];/* Filled in by U-Boot */ clocks = <&emac0_clk>; clock-names = "stmmaceth"; resets = <&rst EMAC0_RESET>; reset-names = "stmmaceth"; snps,multicast-filter-bins = <256>; snps,perfect-filter-entries = <128>; tx-fifo-depth = <4096>; rx-fifo-depth = <4096>; status = "okay"; address-bits = < 48 >; max-frame-size = < 3800 >; phy-mode = "rgmii-id"; snps,phy-addr = < 0xFFFFFFFF >; phy-addr = < 0xFFFFFFFF >; altr,emac-splitter=<&emac_interface_splitter_0>; }; emac_interface_splitter_0: splitter@0xff200000 { compatible = "altr,emac-splitter-1.0"; reg = <0xff200000 0x0001>; clocks = < &clk_emac0_ext >; };
Any advice on this?
Thanks
Vidar
RE: Second PHY MDIO interface - Added by Daniel Vincelette almost 6 years ago
Hi Vidar,
It looks like you are using Critical Link's 4.9 branch, is that correct?
Have you rebuilt and updated your preloader since enabling EMAC0? Seeing as you saw TX data out of the MDIO interface I'm assuming you have but I'm just double checking.
Also I believe you should set the phy-mode to "gmii" because from the HPS' perspective it's connected to the phy over gmiii.
Dan
RE: Second PHY MDIO interface - Added by V J over 5 years ago
Dan, thanks for your feedback. Lesson learned: Always rebuild the preloader.
That fixed my MDIO issue.
Regarding the PHY mode: I am using a 100Mb PHY with RMII interface, and I don’t think my original scheme with the Splitter and RGMII-RMII adapter IPs is possible.
I am using the krogoth branch with kernel 4.1.22-ltsi-rt.
BR
Vidar
