MitySOM-5CSX-H6-4YA Linux kernel 5.15 QSPI NOR Flash access
Added by Mathew Jones about 3 years ago
We’re using the MitySOM-5CSX-H6-4YA and previously we used the Linux kernel 3.16.0 as supplied by CriticalLink, but this time we need to use a more recent kernel (5.13 or later).
I've taken the kernel 5.15.30-lts source from Altera socfpga Github) and have so far built the kernel, modules and device tree blob (DTB).
For the kernel config and the DTB, as there was nothing in the 5.15.30-lts source for the MitySOM-5CSX I based both on source files from kernel 4.9.78-lts as they seem to be the latest from CriticalLink.
The problem I have is that if I boot with kernel 5.15.30-lts I cannot erase or write to a QSPI NOR Flash partition/block (the kernel hangs), but I can read it OK.
Booting kernel 4.9.78-lts I can read, write and erase the QSPI NOR Flash.
Is it possible that I'm missing some kernel configuration settings?
I've seen that 3.16.0 has SPI_CADENCE_QSPI [=y] but neither 4.9.78-lts nor 5.15.30-lts have this parameter.
Also, 3.16.0 and 4.9.78-lts have MTD_M25P80 [=y] but 5.15.30-lts does not have this parameter.
Replies (5)
RE: MitySOM-5CSX-H6-4YA Linux kernel 5.15 QSPI NOR Flash access - Added by Zachary Miller about 3 years ago
Hi Matthew,
It looks like CONFIG_MTD_M25P80 has been superseded by CONFIG_MTD_SPI_NOR, which should already be enabled in the stock 5CSx defconfig from our socfpga-4.9.78-ltsi branch.
Could you post your kernel config and device tree sources? I was able to read, write, and erase on both NOR chips using the following components:
- Altera's socfpga-5.15.30-ltskernel sources
- Stock mitysom5csx_devkit_defconfigfrom Critical Link'ssocfpga-4.9.78-ltsikernel branch, except that I enabledCONFIG_ARCH_INTEL_SOCFPGAinmenuconfig(it was renamed fromCONFIG_ARCH_SOCFPGAat some point)
- Stock socfpga_mitysom5csx-h6-4ya_devkit.dts,socfpga_mitysom5csx.dtsi, andsocfpga_mitysom5cs.dtsifrom Critical Link'ssocfpga-4.9.78-ltsikernel branch
RE: MitySOM-5CSX-H6-4YA Linux kernel 5.15 QSPI NOR Flash access - Added by Mathew Jones about 3 years ago
Thanks Zachary,
Yes CONFIG_MTD_SPI_NOR is set to [y] (as is ARCH_INTEL_SOCFPGA, which initially caught me out as it's was no longer ARCH_SOCFPGA).
I've attached a zip file containing our 5.15.30-lts kernel config and the device tree source files used.
My steps before building the kernel/modules/DTB were essentially:- Copy 4.9.78-lts "arch/arm/configs/mitysom5csx_devkit_defconfig" into 5.15.30-lts (arch/arm/configs/)
- Copy the following 5 DTS files from 4.9.78-lts (arch/arm/boot/dts/) into 5.15.30-lts:
	- socfpga_mitysom5csx-h6-4ya_devkit.dts
- socfpga_mitysom5csx.dtsi
- socfpga_mitysom5cs.dtsi
- socfpga.dtsi
- skeleton.dtsi
- Edit the DTS Makefile (/arch/arm/boot/dts/Makefile) to add socfpga_mitysom5csx-h6-4ya_devkit.dtb
- Edit socfpga_mitysom5cs.dtsi & socfpga_mitysom5csx-h6-4ya_devkit.dts to remove two warnings:
arch/arm/boot/dts/socfpga_mitysom5cs.dtsi:167.12-170.6: Warning (i2c_bus_reg): /soc/i2c@ffc04000/temp@4C: I2C bus unit address format error, expected "4c"
arch/arm/boot/dts/socfpga_mitysom5csx-h6-4ya_devkit.dts:51.13-54.7: Warning (i2c_bus_reg): /soc/i2c@ffc05000/ltc2945@6F: I2C bus unit address format error, expected "6f"- I did change some of the settings in the kernel config, which were network/packet filtering related.
Hi Matthew,
Give it a try with the socfpga.dtsi from Altera's socfpga-5.15.30-lts branch instead (you won't need skeleton.dtsi anymore either). The compatible string for the QSPI controller changed, but the driver also still accepts the old one, resulting in slightly different device configuration. In my testing, that made the difference between write/erase working or not.
As an extra sanity check, I did also test a kernel built with your .config and using my working device tree, and read/write/erase all worked fine.
Hi
That works with socfpga.dtsi from 5.15.30-lts (and no skeleton.dtsi required).
I can now erase, write and read the QSPI NOR Flash.
Thanks a lot.
Good to hear; you're welcome!
