MityDSP: dual port memory within FPGA
Added by Peter Faill over 12 years ago
I'd like to test the DSP <=> FPGA bus interface by writing to a FPGA scratch address and then reading back the results to confirm success.
From the firmware, I see that there is dual-port dual RAM area that appears to exist for testing purposes.
Could you confirm that the base address of the RAM is 0xB000,0180?
I arrived at this address by:
1) 0xB000,0000 sets CE3 (FPGA cs3)
2) address decode is performed on address lines 7 thru 11
3) RAM1 lives at block #3 which results in address: 0x0180 = 011b << 7
I'm assuming that the address lines from the DSP to the FPGA are a one two one mapping (no address shifting done in the schematic/layout).
Thank you,
Peter
RE: MityDSP: dual port memory within FPGA - Added by Michael Williamson over 12 years ago
If you are referring to the bootloader image, then I think you have it.
Address lines are 1-to-1.
RE: MityDSP: dual port memory within FPGA - Added by Peter Faill over 12 years ago
Thanks for the quick reply,
Peter
