Module Product Change Notifications (PCN) and Errata
This page captures PCN's and known errata related to the MityDSP-L138F family of system on modules.
If a part / configuration option is not listed under the "Products Affected" section, then the item was not built/ordered prior to the listed change being issued by engineering.
After you create an account and login, you can use the Watch option to receive email notifications when this page changes. The Watch option will not appear until you login.
Document Type Document Link Title Release/Update Date
Errata MityDSP-L138_Errata MityDSP-L138, MitySOM-1808(F), MitySOM-1810(F) SOM Errata Sheet 8/3/2022
PCN PCN20230801000 128 Mbit NOR Flash Initial: 8/14/2023 Revised: 8/29/2023
PCN PCN20220621000 Remove SATA CLK Driver & JTAG Connector 8/8/2022
PCN PCN20211118000 No Availability of Spartan-6 FPGAs 12/7/2021
PCN PCN20180209000 Obsolete 8MB NOR Flash 2/9/2018
PCN PCN20150626000 Address OMAP-L138 Advisory 2.1.4 6/26/2015
PCN PCN20121031000 Address OMAP-L138 Advisory 2.1.23 10/31/2012
PCN PCN20120612000 RTC Power Current Reduction 6/12/2012
PCN PCN20120524000 SATA A/C decoupling added 5/24/2012
PCN PCN20110711001 Migration from 16-Bit to 8-Bit NAND 6/11/2011
PCN PCN20110711000 Improved CPU Reset 6/11/2011
