The GPIO Core¶
This is a documentation page for using the Critical Link GPIO core.
- The FPGA GPIO Core pins start at pin
#144on the Linux side of things. - So pin
#144will map to the first gpio in the first gpio core. The gpio core will then be connected to a net name which gets mapped to a fpga pin name in the .ucf file. See $MDK/examples/industrial_io/fpga/vhdl/IndustrialIO_rev_C.ucf for example.
Component Instantiation¶
There are effectively three scenarios in which the GPIO core can be instantiated:
- GPIOs as Inputs
GPIO_INST : gpio generic map ( NUM_BANKS => 1, NUM_IO_PER_BANK => 16 ) port map ( clk => ema_clk, i_ABus => addr_r, i_DBus => edi_r, o_DBus => edo5(CORE_GPIO), i_wr_en => wr_r, i_rd_en => rd_r, i_cs => cs5_r(CORE_GPIO), o_irq => irq_map(CORE_GPIO_LVL)(CORE_GPIO_VEC), i_ilevel => conv_std_logic_vector(CORE_GPIO_LVL, 2), i_ivector => conv_std_logic_vector(CORE_GPIO_VEC, 4), i_io => i_gpio, -- GPIO read values t_io => open, -- Direction of GPIOs o_io => open, -- GPIO write values i_initdir => x"0000", -- default to all inputs i_initoutval => x"0000" ); - GPIOs as Outputs
GPIO_INST : gpio generic map ( NUM_BANKS => 1, NUM_IO_PER_BANK => 16 ) port map ( clk => ema_clk, i_ABus => addr_r, i_DBus => edi_r, o_DBus => edo5(CORE_GPIO), i_wr_en => wr_r, i_rd_en => rd_r, i_cs => cs5_r(CORE_GPIO), o_irq => irq_map(CORE_GPIO_LVL)(CORE_GPIO_VEC), i_ilevel => conv_std_logic_vector(CORE_GPIO_LVL, 2), i_ivector => conv_std_logic_vector(CORE_GPIO_VEC, 4), i_io => s_gpio, -- GPIO read values. Loop back output values so they can be read from software. t_io => open, -- Do not care about direction of GPIOs o_io => s_gpio, -- GPIO write values i_initdir => x"FFFF", -- default to all outputs i_initoutval => x"0000" ); -- Set output ports o_gpio <= s_gpio; - GPIOs as Bidirectional Inputs and Outputs
GPIO_INST : gpio generic map ( NUM_BANKS => 1, NUM_IO_PER_BANK => 16 ) port map ( clk => ema_clk, i_ABus => addr_r, i_DBus => edi_r, o_DBus => edo5(CORE_GPIO), i_wr_en => wr_r, i_rd_en => rd_r, i_cs => cs5_r(CORE_GPIO), o_irq => irq_map(CORE_GPIO_LVL)(CORE_GPIO_VEC), i_ilevel => conv_std_logic_vector(CORE_GPIO_LVL, 2), i_ivector => conv_std_logic_vector(CORE_GPIO_VEC, 4), i_io => io_gpio, -- GPIO read values t_io => t_gpio, -- Direction of GPIOs o_io => o_gpio, -- GPIO write values i_initdir => x"FFFF", -- default to all outputs i_initoutval => x"0000" ); -- Process to drive inout ports when GPIO core is in output mode or set to high Z when GPIO core is in input mode GEN_GPIO_IOBS : for i in 0 to 15 generate begin io_gpio(i) <= o_gpio(i) when t_gpio(i) = '0' else 'Z'; end generate GEN_GPIO_IOBS;
