U-boot env userspace tool
U-boot provides a userspace tool you can build, to print and update the u-boot environment stored in mtd4
tools/env/README
root@mityomapl138:~# cat /proc/mtd
mtd0: 08000000 00020000 "rootfs"
mtd1: 08000000 00020000 "homefs"
mtd2: 00010000 00010000 "ubl"
mtd3: 00080000 00010000 "u-boot"
mtd4: 00010000 00010000 "u-boot-env" <---------------
mtd5: 00010000 00010000 "periph-config"
mtd6: 00050000 00010000 "reserved"
mtd7: 00300000 00010000 "kernel"
mtd8: 00200000 00010000 "fpga"
mtd9: 00200000 00010000 "spare"
Build and install
  • Follow instructions to build Das_U-Boot_Port
  • Run makearm env
  • Copy tools/env/fw_printenv to /usr/sbin
  • Symlink fw_setenv
    ln -sf fw_printenv /usr/sbin/fw_setenv
  • Copy tools/env/fw_env.config to /etc/fw_env.config
Use tool
Usage:
   fw_printenv [[ -n name ] | [ name ... ]]
           - prints the value of a single environment variable
             "name", the ``name=value'' pairs of one or more
             environment variables "name", or the whole
             environment if no names are specified.
   fw_setenv name [ value ... ]
           - If a name without any values is given, the variable
             with this name is deleted from the environment;
             otherwise, all "value" arguments are concatenated,
             separated by single blank characters, and the
             resulting string is assigned to the environment
             variable "name"
root@mityomapl138:~# fw_printenv
bootdelay=3
baudrate=115200
root@mityomapl138:~# fw_setenv test 1
root@mityomapl138:~# fw_printenv test
test=1
Read-only
Note if you get a "Can't open /dev/mtd4: Permission denied", the mtd partition may be marked as read-only
  • Check board-mityomapl138.c
    .mask_flags = MTD_WRITEABLE will clear the writeable flag
  • You can also check mtdinfo
    # mtdinfo /dev/mtd4
    mtd4
    Type:                           nor
    Eraseblock size:                65536 bytes, 64.0 KiB
    Amount of eraseblocks:          1 (65536 bytes, 64.0 KiB)
    Minimum input/output unit size: 1 byte
    Sub-page size:                  1 byte
    Character device major/minor:   90:8
    Bad blocks are allowed:         false
    Device is writable:             false  <------
To make the partition writable, you can either remove the .mask_flag line from the mtd partition. board-mityomapl138.c
Or a mtd unlock option was added in our 3.2 kernel but needs to be enabled CONFIG_MTD_UNLOCK
This makes the partition writable until relocked.
echo unlock > /sys/devices/platform/spi_davinci.1/spi1.0/mtd/mtd4/unlock
fw_setenv test 1
echo lock > /sys/devices/platform/spi_davinci.1/spi1.0/mtd/mtd4/unlock
