Base Development Board FPGA Project¶
Overview¶
This project is a base project that was made to test some of the interfaces of the MitySOM 5CSX-H6-42A-RC (Production silicon), which device type 5CSXFC6C6U23C7. Its main features are using the Full HSMC connector as single ended I/O, connecting the FPGA DDR to the HPS memory map, and performing a memory test of the HPS DDR from the FPGA.
- Removing the FPGA DDR controller and Clock Crossing bridge, which also requires removal of the FPGA DDR signals.
- For 5CSX-H6-42A-RC-X, the device type is 5CSXFC6C6U23C8ES.
Updates¶
5/2/2014
- Initial Release
Design Specification¶
The following design was created using Quartus II version 13.1.4 using the following IP blocks:
- Hard Processor System
- Altera PLL
- System ID Peripheral
- PIO (Parallel I/O)
- Merlin Reset Controller
- Avalon-MM Pipeline Bridge
- Modular SGDMA dispatcher
- Modular SGDMA read master
- Modular SGDMA write master
- Altera Avalon Data Pattern Generator
- Altera Avalon Data Pattern Checker
- Clock Source
High Level System Overview¶
Features¶
This project contains the following features:
- Full HSMC connector setup for single ended I/O
- Access to FPGA DDR from HPS memory map
- HPS DDR test from FPGA fabric
Downloads¶
