Building Root Filesystem 23.1
This guide covers the creation of the Critical Link provided Linux filesystem and SDK installation script for the MitySOM-5CSx Dev Kit.
Repository
Description Repository Branch Web Viewer
Critical Link MitySOM-A10S/MitySOM-5CSx meta layer git://support.criticallink.com/home/git/meta-cl-socfpga.git kirkstone gitweb
If you are interested in building or maintaining your own Linux distribution from source for the MitySOM-5CSx family, there is a Yocto compatible meta layer for the module provided at https://support.criticallink.com/gitweb/?p=meta-cl-socfpga.git;a=summary.
The current branch of the Critical Link SOCFPGA is: Kirkstone
The recommended operating system for the build machine: Ubuntu 22.04
Pre-built Kirkstone toolchain: poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-c5-toolchain-4.0.20.sh
Note: Yocto can use around 50GB of space on the host machine.
Setting up the Build Environment
In order to build the filesystem is recommended to use Ubuntu 22.04 LTS with the following packages installed:
Setting up Yocto
  1. Open a terminal
  2. Clone all the needed repositories
    git clone -b kirkstone git://git.yoctoproject.org/poky
    cd poky
    git clone -b kirkstone git://git.openembedded.org/meta-openembedded
    git clone -b kirkstone git://git.yoctoproject.org/meta-ti
    git clone -b kirkstone git://support.criticallink.com/home/git/meta-cl-socfpga.git
  3. Launch the docker container interactively:
  4. You should be inside a bash shell of the docker contain. Source the yocto environment
    . ./oe-init-build-env
  5. Copy the Critical Link's Example configuration files into the build/conf
    cp ../meta-cl-socfpga/conf/bblayers.conf.sample conf/bblayers.conf
    cp ../meta-cl-socfpga/conf/local.conf.5cs conf/local.conf
Performing the Yocto Build
The following steps will build the filesystem that is used on the Critical Link MitySOM-5CS development kit.
  1. Stay inside the docker container from the previous step, or if you have exited relaunch the container in the poky folder:
  2. Source the yocto environment
  3. Build the filesystem
    bitbake mitysom-image-base
Outputs
Description Location
Filesystem Tarball <Yocto Directory>/build/tmp/deploy/images/mitysom-5cs/mitysom-image-base-mitysom-5cs.tar.gz
Build the SDK
The following steps will build the SDK with the cross-compiler toolchain that is used on the Critical Link MitySOM-5CS development kit.
Outputs
Filesystem Tarball <Yocto Directory>/build/tmp/deploy/sdk/poky-glibc-x86_64-mitysom-image-base-cortexa9hf-neon-mitysom-c5-toolchain-4.0.20.sh
Further Reading
