Installing Quartus II 13.0sp1 on Xubuntu 12.04
Note: These steps also work for Xubuntu 13.10
The virtual machine image included with the MityARM-5CSX Development Kit already has Quartus II installed. This wiki page will summarize our suggestions for those attempting a manual install.
In order to install Quartus II 13.0sp1 on a 64 bit machine make sure 32bit libraries are installed because the installer used 32bit libraries
sudo apt-get install ia32-libs
In order to install Quartus under /opt/ sudo must be used for the install:
sudo setup.sh
Once installed make sure that the /altera/quartus directory that is in the users home directory is owned by the user:
sudo chown -R user_name /altera/quartus
Also make sure that the settings directory is owned by the user so that recent projects and window sizes are remembered:
sudo chown -R user_name:user_name ~/.altera.quartus
Driver Installation For USB Blaster
  1. Use root permissions to create file /etc/udev/rules.d/51-usbblaster.rules
  2. Set content to the following:
    # Altera USB-Blaster rule to set mode to 666.
    SUBSYSTEM=="usb",\
    ENV{DEVTYPE}=="usb_device",\
    ATTR{idVendor}=="09fb",\
    ATTR{idProduct}=="6001",\
    MODE="0666",\
    NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}",\
    RUN+="/bin/chmod 0666 %c"
  3. Save and run the following command:
    sudo udevadm control --reload-rules
  4. You may still need to do a dance with what gets plugged in first if you are using the terminal on the same computer...
    1. In my case I needed to have the terminal plugged in and connected.
    2. Then I plugged in the USB blaster into the computer, which reset the board.
    3. Then the USB blaster could scan the JTAG chain and find the FPGA.
