Yocto with Qt5¶
This page demonstrates how to build Qt5.7 using Yocto Krogoth(2.1).
The following layers will be needed:
repo | branch | |
poky | git://git.yoctoproject.org/poky | krogoth |
openembedded | git://git.openembedded.org/meta-openembedded | krogoth |
openembedded-core | git://git.openembedded.org/openembedded-core | krogoth |
qt5 | git://code.qt.io/yocto/meta-qt5.git | 5.7 |
criticallink | git://support.criticallink.com/home/git/meta-mitysom-5csx.git | krogoth |
ti | git://git.yoctoproject.org/meta-ti | krogoth |
Guide¶
- First start by checking out the needed layers
[users@machine:~] git clone -b krogoth git://git.yoctoproject.org/poky [users@machine:~] cd poky [users@machine:~/poky] git clone -b krogoth git://support.criticallink.com/home/git/meta-mitysom-5csx.git [users@machine:~/poky] git clone -b krogoth git://git.openembedded.org/meta-openembedded [users@machine:~/poky] git clone -b 5.7 git://code.qt.io/yocto/meta-qt5.git [users@machine:~/poky] git clone -b krogoth https://github.com/openembedded/openembedded-core.git [users@machine:~/poky] git clone -b krogoth git://git.yoctoproject.org/meta-ti
- Next source the environment setup script
[users@machine:~/poky] . ./oe-init-build-env
- Add the needed layers to your conf/bblayers.conf: (*Note: edit the absolute paths to match your system)
bblayers.conf:# POKY_BBLAYERS_CONF_VERSION is increased each time build/conf/bblayers.conf # changes incompatibly POKY_BBLAYERS_CONF_VERSION = "2" BBPATH = "${TOPDIR}" BBFILES ?= "" BBLAYERS ?= " \ /space/dvincelette/poky/meta \ /space/dvincelette/poky/meta-poky \ /space/dvincelette/poky/meta-yocto-bsp \ /space/dvincelette/poky/openembedded-core/meta \ /space/dvincelette/poky/meta-openembedded/meta-oe \ /space/dvincelette/poky/meta-qt5 \ /space/dvincelette/poky/meta-ti \ /space/dvincelette/poky/meta-mitysom-5csx \ "
- Build the mitysom-image-x11qt5 image
bitbake mitysom-image-x11qt5
Misc¶
menuconfig fails for poky toolchain¶
Eror:
> make menuconfig *** Unable to find the ncurses libraries or the *** required header files. *** 'make menuconfig' requires the ncurses libraries. *** *** Install ncurses (ncurses-devel) and try again. *** make[1]: *** [scripts/kconfig/dochecklxdialog] Error 1 make: *** [menuconfig] Error 2
In case menuconfig fails with a warning about needing nurses try to install the following:
sudo apt-get install lib32ncurses5-dev sudo apt-get install lib32ncursesw5-dev
