iproute2 for SocketCAN with 3.2 Kernel
Added by edward lambert almost 10 years ago
The iproute2 utility for linux 3.2 seems to be unavailable from opkg. I am therefore unable to run the example in the wiki, which I was hoping to use to prove the CAN interface. Is there another way to access the CAN interface or to acquire this utility that you know of?
The current feed for opkg is
src/gz base http://feeds.angstrom-distribution.org/feeds/v2012.05/ipk/eglibc/armv5te/base
Ed
Replies (5)
RE: iproute2 for SocketCAN with 3.2 Kernel - Added by Jonathan Cormier almost 10 years ago
Which wiki page are you referencing?
There should be no need to install any packages. I've attached our cantest script. It expects can0 to be connected to can1.
| cantest.sh (2.79 KB) cantest.sh |
Added a 335x specific CAN wiki page: Using_CAN_port
RE: iproute2 for SocketCAN with 3.2 Kernel - Added by edward lambert almost 10 years ago
Thanks for the quick response.
I'm afraid I posted this in the wrong topic yesterday, I am using an Industrial IO board with an omap L138 arm 9, not a cortex A8.
I am referring to this wiki page https://support.criticallink.com/redmine/projects/indio/wiki/CAN_support.
Okay, would you mind creating a forum post over there as it may help people find it in the future who are looking for a similar issue?
