MMC/SD Card and USB Throughput¶
Testing was performed on a 3354-HX-X38-RC module in a devkit rev. 3A, running the filesystem from the mitysom-335x-devkit-MDK-2017-03-06.sh Yocto based MDK.The real speeds were calculated by dividing the amount of data transferred by the real time taken for the transfer as reported by the time command.
Conclusions:
Write Speed
Memory Device | Data Transferred | Real Time Taken | Real Speed = Real Time / Data Transferred |
Card 1 | 671 MB | 98.751 s | 6.79 MB/s |
Card 2 | 671 MB | 233.585 s | 2.87 MB/s |
Card 3 | 671 MB | 530.657 s | 1.26 MB/s |
USB 1 | 671 MB | 146.429 s | 4.58 MB/s |
USB 2 | 671 MB | 78.453 s | 8.55 MB/s |
Card 1 | 671 MB | 34.039 s | 19.68 MB/s |
Card 2 | 671 MB | 37.137 s | 18.07 MB/s |
Card 3 | 671 MB | 51.866 s | 12.94 MB/s |
USB 1 | 671 MB | 119.528 s | 5.61 MB/s |
USB 2 | 671 MB | 113.329 s | 5.92 MB/s |
- Card 1 -- Class 10 Sandisk micro SD card in a Kingston Adapter
- Card 2 -- Class 4 Verbatim full size SD card
- Card 3 -- Class 4 Kingston micro SD card in a Kingston Adapter
- USB 1 -- Verbatim 4GB flash drive
- USB 2 -- Patriot Memory 8GB flash drive
Note that the use of the command "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 conv=fdatasync" was considered, however it was determined that the output of this command was equivalent to the amount of data transferred (671 MB) divided by the real time taken for the transfer as reported by the time command. T
h4. Write Speed Tests
Card 1
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 95.5386 s, 7.0 MB/s real 1m38.751s user 0m0.130s sys 0m14.290s
Card 2
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 219.389 s, 3.1 MB/s real 3m53.585s user 0m0.040s sys 0m13.820s
Card 3
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 494.305 s, 1.4 MB/s real 8m50.657s user 0m0.080s sys 0m14.650s
USB 1 -- Using Card 1 as the boot device
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/sda1/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 124.768 s, 5.4 MB/s real 2m26.429s user 0m0.110s sys 0m18.400s
USB 2 -- Using Card 1 as the boot device
root@mitysom-335x:~# time sh -c "dd if=/dev/zero of=/run/media/sda1/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 67.6266 s, 9.9 MB/s real 1m18.453s user 0m0.170s sys 0m20.010s
Read Speed Tests¶
Card 1
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 33.9662 s, 19.8 MB/s real 0m34.039s user 0m0.120s sys 0m8.180s
Card 2
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 37.0589 s, 18.1 MB/s real 0m37.137s user 0m0.200s sys 0m7.880s
Card 3
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/mmcblk0p3/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 48.0956 s, 14.0 MB/s real 0m51.886s user 0m0.130s sys 0m7.910s
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/sda1/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 119.45 s, 5.6 MB/s real 1m59.528s user 0m0.100s sys 0m7.400s
root@mitysom-335x:~# time sh -c "dd of=/dev/null if=/run/media/sda1/outfile bs=64k count=10240 && sync" 10240+0 records in 10240+0 records out 671088640 bytes (671 MB) copied, 113.25 s, 5.9 MB/s real 1m53.329s user 0m0.090s sys 0m7.420s
Other¶
Throughput testing was performed to determine loading speeds from both the MMC/SD to RAM.
MMC/SD Card to RAM - UBoot
9588 KBytes/sec Average
ERASE RAM: mw.b 0x82000000 0xff 0x5000000 MMC LOAD: fatload mmc 0:1 82000000 root.jffs2
MMC/SD Card to RAM - Linux
TBD
