SLMitySBC A5E
MW RE: MitySBC A5E - Added by Michael Williamson 9 months ago
Hi Sung,
From the datasheet (page 14):
"All power to the FMC connector is gated by FMC_EN_3V3 which is tied to pin CG134 of the FPGA."
This will enable the +12V FMC power supply and the +3.3V FMC power Supply. VADJ should already be enabled is currently set to 1.8V (via a zero ohm resistor labelled "JP1") and can be set to 3.3V using pads on "JP2".
I will check and see if we have a reference project for these connections.
Reference projects for the SBC can be found here:
https://support.criticallink.com/redmine/projects/mitysbc_a5/wiki
SL RE: MitySBC A5E - Added by Sung Lim 9 months ago
Thank you for the information. I am guessing the pre-installed FPGA does not enable FMC_EN_3V3.
I will start with one of the available reference projects.
Best regards, Sung Lim
