CAD Files and Information
MitySOM-A5E Standard
A Step model as well as an Altium Integrated Library are included below for use with MitySOM-A5E Standard Carrier Card designs. The Integrated library package includes 4 different schematic symbols:
  1. one presents the connector symbol for J1 as a 4 parts for each SEAM connector in pin order (A1-A50, B1-B50, etc.).
  2. one presents the connector symbol for J1 as 9 parts for the SEAM connector, with the pins organized into functional blocks (e.g., power and ground connections, transceiver blocks, IO banks, etc.).
  3. one presents the connector symbol for J2 as a 4 parts for each SEAM connector in pin order (A1-A50, B1-B50, etc.).
  4. one presents the connector symbol for J2 as 7 parts for the SEAM connector, with the pins organized into functional blocks (e.g., power and ground connections, transceiver blocks, IO banks, etc.).
The footprints for the J1 symbol includes the recommended Samtec connector land pattern, the SOM board outline, a location reference for the center location of J2, and location references for both the MitySOM-A5E Standard mounting hole locations (outer 4 locations) and the MitySOM-A5E Mini mounting hole locations (center 2 locations, bottom 2 locations).
The footprint for the J2 symbol does not include the additional reference locations; it only includes the PCB land pattern of the Samtec connector.
Production / Revision 1 Data
Integrated_Library_MitySOM_A5E_Standard_2025_12_01.zip : Altium Schematic Symbol and footprint for MitySOM-A5E Standard to be used on carrier card.
MitySOM_A5E_Standard_656KLE.zip : MitySOM-A5E Standard, Revision -1 Step Model, 656KLE
MitySOM-A5E Mini
A Step model as well as an Altium Integrated Library are included below for use with MitySOM-A5E Mini Carrier Card designs. The Integrated library package includes 2 different schematic symbols, one presents the connector symbol for J1 as a 4 parts for the SEAM connector in pin order (A1-A50, B1-B50, etc.). A second symbol presents the symbol as 9 parts for the SEAM connector, with the pins organized into functional blocks (e.g., power and ground connections, transceiver blocks, IO banks, etc.). The footprints for the J1 symbol includes the recommended Samtec connector land pattern, the SOM board outline and location references for both the MitySOM-A5E Mini Standard mounting hole locations.
Production / Revision 2 Data
MitySOM_A5ED_Rev-2A_2024_10_18.zip : MitySOM-A5E Mini, Revision -2A Step Model
Integrated_Library_MitySOM_A5E_Mini_2025_12_01.zip : Altium Schematic Symbol and footprint for MitySOM-A5E Mini to be used on carrier card.
Older files...
MitySOM-A5E Mini Prototype files...
