Building the FPGA project and Bootloader with Quartus Pro 25.3¶
Introduction¶
The reference project for the MitySOM-A5E requires the Quartus Pro 25.3 tools installed and in your path.
| Platform | Description | Repository | Branch |
| Mity-A5E | Quartus Example Projects | git://support.criticallink.com/home/git/mitysom-a5e-ref.git | pro_25.3_stable |
Quick steps to build¶
Clone the repository¶
git clone -b pro_25.3_stable git://support.criticallink.com/home/git/mitysom-a5e-ref.git
Navigate into the folder for the reference Quartus project desired to build (E.g. MODEL_NUMBER/mitysom-a5e-mini-ref-base)¶
cd mitysom-a5e-ref/A5ED-B14-1X8-MRC-B0/mitysom-a5e-mini-ref-base
make jic
Program the QSPI NOR with the preloader¶
Bootloader¶
Bootloader Environment¶
The bootloader environment script can be found in scripts/boot.cmd. This is bootloader script that is ran as part of the boot process. The script can be compiled by running the following:
make uboot_script
The compiled output script will be in scripts/boot.scr, this belongs in the FAT partition
