Building the Filesystem
Introduction
The filesystem is built through Yocto. The Yocto version is scarthgap and should be compiled using Ubuntu 22.04.
The meta-layers for the Yocto build are as follows.
Repository URL Branch
poky https://git.yoctoproject.org/poky scarthgap
meta-openembedded https://github.com/openembedded/meta-openembedded scarthgap
meta-mitysom https://support.criticallink.com/git/meta-mitysom.git scarthgap
It is recommended to use Docker for the Yocto build. Instructions for installing Docker can be found here: Docker Installation Guide
The recommended Docker container can be fetched using the command below.
Setting up Yocto
Clone the Yocto layers
git clone -b scarthgap https://git.yoctoproject.org/poky
cd poky
git clone -b scarthgap https://github.com/openembedded/meta-openembedded
git clone -b scarthgap https://support.criticallink.com/git/meta-mitysom.git
Launch the Docker container
Source the Yocto environment
. ./oe-init-build-env
Copy the example configuration files
cp ../meta-mitysom/conf/bblayers.conf.sample conf/bblayers.conf
cp ../meta-mitysom/conf/local.conf.sample conf/local.conf
Performing the Yocto build
Build the filesystem
Standard:
MACHINE=mitysom-agilex5 bitbake mitysom-image-base
Mini:
MACHINE=mitysom-agilex5-mini bitbake mitysom-image-base
Outputs
Platform Description Location
Standard Filesystem Tarball <Yocto Directory>/build/tmp/deploy/images/mitysom-agilex5/mitysom-image-base-mitysom-agilex5.tar.gz
Mini Filesystem Tarball <Yocto Directory>/build/tmp/deploy/images/mitysom-agilex5-mini/mitysom-image-base-mitysom-agilex5.tar.gz
Build the SDK
Build the SDK
Standard:
MACHINE=mitysom-agilex5 bitbake mitysom-image-base -c populate_sdk
Mini:
MACHINE=mitysom-agilex5-mini bitbake mitysom-image-base -c populate_sdk
Outputs
SDK Script <Yocto Directory>/build/tmp/deploy/sdk/mitysom-*mitysom-image-base-*.sh
