Building TI Linux SDK and IPC examples on Linux SDK 06.03¶
- Building TI Linux SDK and IPC examples on Linux SDK 06.03
The process below was done on a 64-bit x86-based Linux host running Ubuntu 18.04.4 LTS using ti-processor-sdk 06.03.00.106 . Please use an acceptable version of Ubuntu such at 18.04.4 LTS with the ti-processor-sdk 06.03.00.106.
TI has a good rundown on the different communication techniques available between the ARM and DSPs. This page is going to focus on some of the IPC and BigData IPC examples.
https://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_IPC.html#multiple-ways-of-arm-dsp-communication
You will need the TI Processor SDK and the TI RTOS Processor SDK for most projects using the ARM and DSP. This guide is intended to supplement TI's documentation, not replace it. It is recommended to read through the referenced documentation.
Useful references:
TI Linux IPC
TI RTOS IPC
TI IPC Training
Downloading and Installing the SDKs from TI¶
Download PROCESSOR-SDK-LINUX-AM57X and PROCESSOR-SDK-RTOS-AM57X from the https://www.ti.com/tool/PROCESSOR-SDK-AM57X
Install TI Processor SDK for Linux. Follow instructions here: http://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Overview/Download_and_Install_the_SDK.html.
After installation, set up the host environment. Link is here: http://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Overview/Run_Setup_Scripts.html.
Note that the instructions refer to a script called sdk-install.sh, which is not in the installation. Skip this script (but note the information)
Proceed to running the ./setup.sh script. At the end of the script, the script loops until an EVM is detected. Just break (ctrl-c) from the script. Make sure to install the bison and flex packages via sudo apt-get install <package> on your machine in order to properly run the IPC make commands.
Install TI RTOS Processor SDK according to the steps here: http://software-dl.ti.com/processor-sdk-rtos/esd/docs/06_03_00_106/rtos/index_overview.html.
Note: TI recommends using the same version of Linux SDK as RTOS SDK. As such we are renaming the default rtos install location to include this version number for future sanity. This will mean code composer will need to be told of this location if you plan on using it
$ chmod +x ti-processor-sdk*.bin $ ./ti-processor-sdk-linux-am57xx-evm-06.03.00.106-Linux-x86-Install.bin Destination Folder [/home/jcormier/ti-processor-sdk-linux-am57xx-evm-06.03.00.106]: $HOME/ti-processor-sdk-linux-am57xx-evm-06.03.00.106 $ ./ti-processor-sdk-rtos-am57xx-evm-06.03.00.106-Linux-x86-Install.bin --prefix $HOME/ti-processor-sdk-rtos-am57xx-evm-06.03.00.106 Destination Folder [/home/jcormier/ti]: $HOME/ti-processor-sdk-rtos-am57xx-evm-06.03.00.106
Building the IPC libraries¶
Build the IPC libraries and examples by following steps here: http://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_IPC.html#ipc-for-am57xx
- Setup environment
export TI_SDK_PATH=$HOME/ti-processor-sdk-linux-am57xx-evm-06.03.00.106 export PATH=$TI_SDK_PATH/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/:$PATH export TI_RTOS_PATH=$HOME/ti-processor-sdk-rtos-am57xx-evm-06.03.00.106 export IPC_INSTALL_PATH=$TI_RTOS_PATH/ipc_3_50_04_08 # Env variables for ipc_bios compile export SDK_INSTALL_PATH=$TI_RTOS_PATH export TOOLS_INSTALL_PATH=$TI_RTOS_PATH
- Build the Linux IPC library and examples
cd $TI_SDK_PATH make ti-ipc-linux make ti-ipc-linux-examples cd $TI_RTOS_PATH/processor_sdk_rtos_am57xx_6_03_00_106/ source setupenv.sh make ipc_bios
Reloading DSP/IPU firmware key¶
To load/reload firmware on a live system, you need to unbind and bind the omap remoteproc driver with the name of the processor's rproc device name. Capturing these below for easier reference.
| Processor | Device Name | Remote Proc Number | MultiProc id |
| DSP1 | 40800000.dsp | remoteproc2 | 4 |
| DSP2 | 41000000.dsp | remoteproc3 | 3 |
| IPU1 | 58820000.ipu | remoteproc0 | |
| IPU2 | 55020000.ipu | remoteproc1 | 1 |
Example:
echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/bind
Running the ex02_messageq example¶
Steps to run (assuming booted from tisdk-rootfs-image):
- PC: Create directory on devkit and copy build example files
ssh root@<devkit> mkdir -p ipc-starter/ex02_messageq cd $TI_RTOS_PATH/ipc_3_50_04_08/examples/DRA7XX_linux_elf/ex02_messageq/ scp */bin/debug/{server_dsp*,app_host,server_ipu*} root@<devkit>:ipc-starter/ex02_messageq/ - devkit: Stop opencl daemon which interacts with DSPs. Optionally you can disable it if you don't plan on using opencl by replacing `stop` with `disable`
systemctl stop ti-mct-daemon.service
- devkit: load new firmware on DSPs/IPUs
ln -sf /home/root/ipc-starter/ex02_messageq/server_dsp1.xe66 /lib/firmware/dra7-dsp1-fw.xe66 echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/bind ln -sf /home/root/ipc-starter/ex02_messageq/server_dsp2.xe66 /lib/firmware/dra7-dsp2-fw.xe66 echo 41000000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind echo 41000000.dsp > /sys/bus/platform/drivers/omap-rproc/bind ln -sf /home/root/ipc-starter/ex02_messageq/server_ipu1.xem4 /lib/firmware/dra7-ipu1-fw.xem4 echo 58820000.ipu > /sys/bus/platform/drivers/omap-rproc/unbind echo 58820000.ipu > /sys/bus/platform/drivers/omap-rproc/bind ln -sf /home/root/ipc-starter/ex02_messageq/server_ipu2.xem4 /lib/firmware/dra7-ipu2-fw.xem4 echo 55020000.ipu > /sys/bus/platform/drivers/omap-rproc/unbind echo 55020000.ipu > /sys/bus/platform/drivers/omap-rproc/bind
- devkit: run example arm app
cd /home/root/ipc-starter/ex02_messageq/ ./app_host DSP1 ./app_host DSP2 ./app_host IPU1 ./app_host IPU2
Note: During testing, the IPU1 firmware refused to load, more testing is required. See attachment:ipc_examples.txt
Running the ipc tests¶
NOTE: The ipc tests comes pre-compiled on the tisdk-rootfs-image. Files located at /lib/firmware/ipc/ti_platforms_evmDRA7XX_*/ and the ARM apps are in the system path.
ssh root@<devkit> mkdir -p ipc-tests scp -r $TI_RTOS_PATH/ipc_3_50_04_08/packages/ti/ipc/tests/bin/* root@<devkit>:ipc-tests/ scp -r $TI_RTOS_PATH/ipc_3_50_04_08/linux/src/tests/.libs/* root@<devkit>:ipc-tests/
ln -sf /home/root/ipc-tests/ti_platforms_evmDRA7XX_dsp1/messageq_single.xe66 /lib/firmware/dra7-dsp1-fw.xe66 echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/bind
root@mitysom-am57x:~# ./ipc-tests/MessageQApp 1 4 Using numLoops: 1; procId : 4 Entered MessageQApp_execute Local MessageQId: 0x80 Remote queueId [0x40080] Exchanging 1 messages with remote processor DSP1... MessageQ_get #1 Msg = 0xb64007c0 Exchanged 1 messages with remote processor DSP1 Sample application successfully completed! Leaving MessageQApp_execute root@mitysom-am57x:~# MessageQBench 1000 8 4 Using numLoops: 1000; payloadSize: 8, procId : 4 Entered MessageQApp_execute Local MessageQId: 0x80 Remote queueId [0x40080] Exchanging 1000 messages with remote processor DSP1... DSP1: Avg round trip time: 137 usecs Leaving MessageQApp_execute
Note: DSP1 is procId: 4, DSP2 is procId: 3
Note: As of this posting (03/08/2021) the sdk-linux docs have the wrong MessageQBench arguments. Reported to TI
Timing the IPC latency using MessageQBench¶
Test: Send 3 doubles from the DSP to the ARM
Note: MessageQBench times messages from ARM->DSP->ARM, with messages sent one at a time
Assuming the setup time is static: The example is sending ~7,462 messages a second, double that for both directions.
(2.54s-1.2s)/10000 = 134 us 1/(134us) = 7462
Changing it to floats (12 bytes) resulted in ~10k messages a second.
Also ran two copies of the benchmark to each DSP resulted in the same timings, so we could likely get higher throughput numbers if both DSPs are sending data, assuming the DSP calculations aren't the bottleneck.
Building and running the big-data-ipc example¶
The example itself is described here: http://software-dl.ti.com/processor-sdk-rtos/esd/docs/06_03_00_106/rtos/index_examples_demos.html#big-data-ipc-example. The steps to run the example are in section 9.7.4.2.
NOTE: This example only works on DSP1. If done on DSP2, when binding an infinite loop will occur. We tested this example for throughput and only got ~15MB/s. There is currently a pending e2e post to try and get this resolved. https://e2e.ti.com/support/processors/f/processors-forum/986073/am5728-ipc-big-data-example-gives-low-throughput
NOTE: The big data example comes pre-compiled on the tisdk-rootfs-image. Files located at /usr/bin/simple_buffer_example/release/app_host
- Setup the environment
- PC: Build the big data example
cd $TI_SDK_PATH make big-data-ipc-demo
ssh root@<devkit> mkdir -p ipc-starter/big-data cd $TI_SDK_PATH/example-applications/big-data-ipc-demo-linux-01.03.00.00/host_linux/simple_buffer_example/ scp */bin/DRA7XX/release/{server_dsp*,app_host} root@<devkit>:ipc-starter/big-data - devkit: Stop opencl daemon which interacts with DSPs. Optionally you can disable it if you don't plan on using opencl by replacing `stop` with `disable`
ln -sf /home/root/ipc-starter/big-data/server_dsp.xe66 /lib/firmware/dra7-dsp1-fw.xe66 echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/unbind echo 40800000.dsp > /sys/bus/platform/drivers/omap-rproc/bind
cd /home/root/ipc-starter/big-data/ ./app_host DSP1
Note: The Shutdown message sent from the ARM causes the DSP to stop running. Reloading DSP firmware was enough to get it back working
tail /sys/kernel/debug/remoteproc/remoteproc2/trace0 [ 9.547] [t=0x00000001:47d3f6e9] Server: Message received...1 [ 9.547] [t=0x00000001:47d50dbc] ti.sdo.ipc.SharedRegion: ERROR: line 536: assertion failure: A_overlap: Shared region overlaps [ 9.547] ti.sdo.ipc.SharedRegion: line 536: assertion failure: A_overlap: Shared region overlaps [ 9.547] xdc.runtime.Error.raise: terminating execution
Summary of how the big data example works:¶
ARM Code:- Create 16MB shared memory region using CMEM and SharedRegion
- Create a Heap which is used to split this shared memory into trackable chunks to send over to the DSP
- SEND: Send the shared memory pointer to DSP so it can setup its SharedRegion to match
- SEND: Send 2 no-op messages
The no-op messages are priming the pump so to speak. The ARM app is set up to only send more messages when it receives one. So sending 2 no-op messages ensures there are 3 messages in flight at a time, one for DSP to process, one for ARM, and one in waiting. To try and keep all processors active. - RECV: Get a response MSG from DSP
- If the message is a BIGDATA message, then validate DSP count pattern and free the buffer
- SEND: For every message received, we send a BIGDATA message allocated from the Heap filled with the ARM count pattern to DSP
- For the last 3 messages, send 2 no-ops and then 1 shutdown message
- RECV: Get a message from ARM
- If the message is a SETUP message, setup SharedRegion using info from ARM
- If the message is a BIGDATA message, then validate the ARM count pattern and replace it with a DSP count pattern. Send the message back to ARM
The Heap is only accessed directly by the ARM code. The buffers acquired from the Heap are only accessed by one processor at a time so no locks are required.
Note: The example is designed around the expectation that the ARM is sending data to the DSP to operate on and then it gets returned. If the DSP generated data on its own and then sends it to ARM, it may be beneficial for the DSP to own the Heap management
Note: Updated Big Data example to allow the number of messages and the buffer size to be adjusted by command line arguments. https://github.com/jcormier/big-data-ipc-example/commits/benchmark
Creating a custom project using an example as a starting point¶
TODO
Errors¶
Failed to get a pool fitting a size 0x1000000root@mitysom-am57x:~/ipc-starter/big-data# /usr/bin/simple_buffer_example/release/app_host DSP1 [112/2022] --> main: --> Main_main: --> App_create: App_create: Host is ready <-- App_create: --> App_exec: CMEM_init success CMEM Error: getPool: Failed to get a pool fitting a size 0x1000000 CMEM_getPool failed Segmentation fault (core dumped)
Ensure that the opencl ti-mct-daemon service is stoppedsystemctl stop ti-mct-daemon.service
Problem running post-install step. Installation may not complete correctly.
This error may occur while installing the Processor RTOS packages. Please install on a different machine and transfer the necessary packages into the workspace you are working in. The RTOS directory should look like the following:
user@pc:~$ ls ti-processor-sdk-rtos-am57xx-evm-06.03.00.106 bios_6_76_03_01 gcc-arm-none-eabi-7-2018-q2-update opencl_rtos_am57xx_1.2.00.02 ti-cgt-pru_2.3.2 cg_xml_2.61.00 imglib_c66x_3_1_1_0 openmp_dsp_am57xx_2_06_03_00 uia_2_30_01_02 ctoolslib_2_2_0_0 ipc_3_50_04_08 pdk_am57xx_1_0_17 xdais_7_24_00_04 dsplib_c66x_3_4_0_4 mathlib_c66x_3_1_2_4 processor_sdk_rtos_am57xx_6_03_00_106 xdctools_3_55_02_22_core edma3_lld_2_12_05_30E ndk_3_61_01_01 ti-cgt-arm_18.12.5.LTS framework_components_3_40_02_07 ns_2_60_01_06 ti-cgt-c6000_8.3.2
