Sign in
Redmine shortcuts
Search
MitySOM-AM57X
All Projects
Mity CPU Platforms
MitySOM-AM57X
Activity
Forums
Advanced Peripherals
SOM Cortex-M4s
SOM DSP Custom Code
SOM DSP IPC
SOM DSP OpenCL
SOM DSP OpenMP
SOM FPGA GPMC interface
SOM FPGA PCIe
SOM PRUs
USB 3 Dual Role
AM57x Development Kit
Arm Development
Code Composer Installation
Docker build environment
Gdb Multiarch Installation
Kernel Splash Screen
Linux Application Using Gpio
Linux App CCS CCS Project
Linux App CCS C Project
Linux App Visual Studio Code
Linux Kernel
Linux Kernel Debugging
Linux Kernel SDK 903
QT Starter Guide 2022
U-Boot Bootstrapping process
U-Boot Debugging
U-Boot Setup Pinmux
Change Core Clock Frequency
DSP Development
Building DSP Example Projects
DSP Development Environment
DSP JTAG Debug via CCS
JTAG Debug Interface
FPGA Development
AM57xx FPGA Communication
FPGA Example Projects
FPGA Overview
Frequently Asked Questions
ARM Software FAQs
Getting Started
Example - 1gb Ethernet
N Setting Static IP Address
Example - Hello World
Example - USB Serial Console
Example 10 100mb Ethernet
Example audio line
Example Baseboard Fan Control
Example EEPROM
Example hdmi
Example i2c
Example RNDIS
Example SATA
Example SOM Clock Speeds
Example SOM PMIC
Example SOM QSPI NOR
Reading Temperature
SoM Temperature Sensors
Example SOM tricolor LED
Example usb
Example WiFi Bluetooth
Hardware Design
CAD Files and Information
Clearance Beneath Module
Hardware Design Guidelines
Mounting Hole Locations
MXM Connector Information
On-Module Trace Lengths
Shock and Vibration
Test Point Overview
Memory Overview
Release Notes
Start page
Index by title
Index by date
MitySOM-AM57x Wiki
SOM DSP IPC
TODO
Objective
Steps
Conclusion
Files (0)
Loading...
Add picture from clipboard
(Maximum size: 1 GB)
