ARM/R5 JTAG Debugging¶
Requires: Code Composer (CCS) v7+
Instructions tested on CCS v12.8 with XDS200 emulator
These instructions assume the board is booted via u-boot and as such ARM clocks and DDR settings are already setup.
- Connect debugger to computer and board
- Open Code Composer (CCS)
- File -> New -> Target Configuration File
- File name: {SOM_NAME}_XDS200.ccxml
- Check "Use shared location"
- Click Finish
- Edit opened Target Configuration
- Connection: Select the correct debug probe.
"Texas Instruments XDS2xx USB Debug Probe" for the XDS200 - Board or Device: AM62A/P
- Select Save
- Select Test Connection
attachment:xds200_debug_test_connection.log
- View -> Target Configurations
- In the Target Configuration view, expand the "User Defined folder"
- Right click on the new Target Configuration File and select the "Launch Selected Configuration"
- If a firmware update warning window opens, select Update
If you get an error during update, try updating manually: https://software-dl.ti.com/ccs/esd/documents/xdsdebugprobes/emu_xds200.html#updating-the-firmware
- Open Target Status view, this shows each of the slave cores Power, Clocks, and reset status
- View -> Other, Select Debug/Target Status and Open
- Connect to A53SS0_CORE1_0
- Right click on A53SS0_CORE1_0 and select "Connect to target"
- Make sure to resume the core before too long or Linux will get a bit angry, Run -> Resume
- Load GEL FILE
- Ensure A53SS0_CORE1_0 is selected
- Navigate to toolbar>Tools>GEL Files
- In the GEL Files view (usually in bottom right), Select the GEL files category
- Right click in the empty space under "Script | Status", and select "Load GEL..."
- Open the following gel file: C:\ti\ccs1120\ccs\ccs_base\emulation\gel\{AM62A/P}\{AM62A/P}.gel
- With the A53SS0_CORE1_0 suspended, select Scripts and explore the different options
- View physical memory addresses
- With any core suspended, View -> Memory Browser
