Booting from OSPI / QSPI
See Boot_options for more details about the boot select pins
NOTE: Booting from OSPI is a different boot config than QSPI
OSPI Boot
To boot the Dev Kit from OSPI using a CL supplied image, set the boot pins as follows:
B9 B8 B7 B6 B5 B4 B3
Reserved (0) lclk (1) Csel (0) 0 0 0 1
QSPI Boot
To boot the Dev Kit from QSPI using a CL supplied image, set the boot pins as follows:
Reserved (0) lclk (1) Csel (0) 0 0 1 0
Steps
  • boot to linux (i.e. from SD card).
  • Check that the spi nor was detected
    root@mitysom-am62x:~# cat /proc/mtd
    dev:    size   erasesize  name
    mtd0: 00080000 00020000 "ospi.tiboot3"
    mtd1: 00200000 00020000 "ospi.tispl"
    mtd2: 00400000 00020000 "ospi.u-boot"
    mtd3: 00040000 00020000 "ospi.env"
    mtd4: 00040000 00020000 "ospi.env.backup"
    mtd5: 0f7c0000 00020000 "ospi.rootfs"
    mtd6: 00040000 00020000 "ospi.phypattern"
  • cd to boot partition (the directory containing tibot3.bin, etc.../run/media/mmcblk1p1 in my case.)
  • Erase the NOR partitions
    root@mitysom-am62x:~# flash_erase /dev/mtd0 0 0
    root@mitysom-am62x:~# flash_erase /dev/mtd1 0 0
    root@mitysom-am62x:~# flash_erase /dev/mtd2 0 0
  • copy the boot files to their respective locations in SPI NOR
    root@mitysom-am62x:~# cp tiboot3.bin /dev/mtd0
    root@mitysom-am62x:~# cp tispl.bin /dev/mtd1
    root@mitysom-am62x:~# cp u-boot.img /dev/mtd2
    root@mitysom-am62x:~# dd if=/dev/mmcblk0boot0 bs=512 iskip=13312 count=256 of=/dev/mtd3
      0x0 +----------------------------+
          |     ospi.tiboot3(512k)     |
  0x80000 +----------------------------+
          |     ospi.tispl(2m)         |
 0x280000 +----------------------------+
          |     ospi.u-boot(4m)        |
 0x680000 +----------------------------+
          |     ospi.env(128k)         |
 0x6c0000 +----------------------------+
          |   ospi.env.backup(128k)    |
 0x740000 +----------------------------+
          |      padding (768k)        |
 0x800000 +----------------------------+
          |     ospi.rootfs(ubifs)     |
0xffc0000 +----------------------------+
          |   ospi.phypattern (256k)   |
