MitySOM-AM62 CSI-2 Camera Capture¶
The AM62x and AM62p is able to stream image data from MIPI/CSI-2 cameras capable of generating images with YUV or RGB colorspace output. The AM62x does not include hardware based debayering / Image Signal Processing (ISP) accelerators.
This example outlines examples streaming or capturing image data from a couple of off-the-shelf cameras.
The connector interface on the MitySOM-AM62 Development kit is intended to be compatible with the Raspberry Pi zero 22-pin 0.5 mm pitch interface. Connections for MIPI cameras utilizing the Raspberry Pi 15 pin 1.0mm pitch interface can be made with a 15-pin to 22-pin flex cable adaptor, such as the Arducam Raspberry Pi Camera Cable.
Video streaming is supported across a range of resolutions, starting from 120p at 30fps and scaling up to 1944p at 15fps.
Using a Digilent PCAM 5C Camera¶
The Digilent PCAM 5C camera is a 5MP camera based on the ov5640 sensor from Omni-Vision.
Connect the camera.¶
The pictures below show the connections for the camera to the development kit using the Arducam adapter cable. Note that the conductors must be on the top side of the MitySOM-AM62 evaluation board interface.
Configure to use the MitySOM-AM62 Development Kit OV5640 Overlay¶
Add this line to /run/media/boot-mmcblk1p1/uEnv.txt and reboot:
For the AM62xname_overlays=k3-am625-mitysom-ov5640.dtbo
For the AM62pname_overlays=k3-am62px-mitysom-ov5640.dtbo
Option 1: TI Demo¶
The TI default Demo comes with a live camera stream demo, which can detect the camera and stream it to the screen. Simple select "Live Camera" and the stream should start.
Option 2: GStreamer through Wayland¶
640x480, 30 Hz
media-ctl -d 0 --set-v4l2 "'ov5640 1-003c':0 [fmt:UYVY/640x480]"; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:UYVY/640x480]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:UYVY/640x480]' gst-launch-1.0 v4l2src device="/dev/video0" ! video/x-raw, width=640, height=480, format=UYVY ! autovideosink
1024x768, 30 Hz
media-ctl -d 0 --set-v4l2 "'ov5640 1-003c':0 [fmt:UYVY/1024x768]"; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:UYVY/1024x768]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:UYVY/1024x768]' gst-launch-1.0 v4l2src device="/dev/video0" ! video/x-raw, width=1024, height=768, format=UYVY ! autovideosink
Streaming at higher resolutions using a single command¶
For this example a 1080p resolution is used.
gst-launch-1.0 libcamerasrc ! video/x-raw, width=1920, height=1080, format=UYVY ! autovideosink
Option 3: GStreamer through KMS¶
640x480, 30 Hz
systemctl stop weston.socket; systemctl stop weston media-ctl -d 0 --set-v4l2 "'ov5640 1-003c':0 [fmt:UYVY/640x480]"; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:UYVY/640x480]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:UYVY/640x480]' gst-launch-1.0 v4l2src device="/dev/video0" ! video/x-raw, width=640, height=480, format=UYVY ! queue ! kmssink driver-name=tidss plane-properties=s,zpos=1
1024x768, 30 Hz
systemctl stop weston.socket; systemctl stop weston media-ctl -d 0 --set-v4l2 "'ov5640 1-003c':0 [fmt:UYVY/1024x768]"; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:UYVY/1024x768]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:UYVY/1024x768]' gst-launch-1.0 v4l2src device="/dev/video0" ! video/x-raw, width=1024, height=768, format=UYVY ! queue ! kmssink driver-name=tidss plane-properties=s,zpos=1
Using controls¶
The OV5640 and driver does have V4L2 controls to allow generation of test patterns as well as flipping X and Y on the output:
root@mitysom-am62x:~# v4l2-ctl -L -d /dev/v4l-subdev2 User Controls contrast 0x00980901 (int) : min=0 max=255 step=1 default=0 value=0 flags=slider saturation 0x00980902 (int) : min=0 max=255 step=1 default=64 value=64 flags=slider hue 0x00980903 (int) : min=0 max=359 step=1 default=0 value=0 flags=slider white_balance_automatic 0x0098090c (bool) : default=1 value=1 flags=update red_balance 0x0098090e (int) : min=0 max=4095 step=1 default=0 value=0 flags=inactive, slider blue_balance 0x0098090f (int) : min=0 max=4095 step=1 default=0 value=0 flags=inactive, slider error 121 getting ctrl Exposure gain_automatic 0x00980912 (bool) : default=1 value=1 flags=update horizontal_flip 0x00980914 (bool) : default=0 value=0 vertical_flip 0x00980915 (bool) : default=0 value=0 power_line_frequency 0x00980918 (menu) : min=0 max=3 default=1 value=1 (50 Hz) 0: Disabled 1: 50 Hz 2: 60 Hz 3: Auto Camera Controls error 121 getting ext_ctrl Auto Exposure Image Source Controls vertical_blanking 0x009e0901 (int) : min=24 max=2895 step=1 default=600 value=600 horizontal_blanking 0x009e0902 (int) : min=1256 max=1256 step=1 default=1256 value=1256 flags=read-only error 121 getting ext_ctrl Analogue Gain Image Processing Controls link_frequency 0x009f0901 (intmenu): min=0 max=22 default=13 value=13 (384000000 0x16e36000) flags=read-only 0: 992000000 (0x3b20b800) 1: 888000000 (0x34edce00) 2: 768000000 (0x2dc6c000) 3: 744000000 (0x2c588a00) 4: 672000000 (0x280de800) 5: 672000000 (0x280de800) 6: 592000000 (0x23493400) 7: 592000000 (0x23493400) 8: 576000000 (0x22551000) 9: 576000000 (0x22551000) 10: 496000000 (0x1d905c00) 11: 496000000 (0x1d905c00) 12: 384000000 (0x16e36000) 13: 384000000 (0x16e36000) 14: 384000000 (0x16e36000) 15: 336000000 (0x1406f400) 16: 296000000 (0x11a49a00) 17: 288000000 (0x112a8800) 18: 248000000 (0xec82e00) 19: 192000000 (0xb71b000) 20: 192000000 (0xb71b000) 21: 192000000 (0xb71b000) 22: 96000000 (0x5b8d800) pixel_rate 0x009f0902 (int64) : min=48000000 max=168000000 step=1 default=48000000 value=48000000 flags=read-only test_pattern 0x009f0903 (menu) : min=0 max=4 default=0 value=0 (Disabled) 0: Disabled 1: Color bars 2: Color bars w/ rolling bar 3: Color squares 4: Color squares w/ rolling bar root@mitysom-am62x:~# v4l2-ctl --set-ctrl=test_pattern=3 -d /dev/v4l-subdev2 root@mitysom-am62x:~# v4l2-ctl --set-ctrl=horizontal_flip=1 -d /dev/v4l-subdev2
Using a Raspberry Pi-2 Camera¶
The Raspberry Pi-2 camera is an 8MP camera based on the imx219 sensor from Sony. The imx219 only presents data as raw pixels (bayer pattern), so the camera cannot be directly streamed to the display as there is no ISP on the AM62x platform to perform the colorspace conversion. This feature is avalable on the AM62xa, see this page for more info. However, you can still capture a single image and either display it on screen, or save it to disk:
Configure overlay¶
Add this line to /run/media/boot-mmcblk1p1/uEnv.txt and reboot:name_overlays=k3-am625-mitysom-imx219.dtbo
Take and display image:¶
systemctl stop weston media-ctl --set-v4l2 '"imx219 1-0010":0[fmt:SRGGB8/1920x1080]'; ; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:SRGGB8/1920x1080]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:SRGGB8/1920x1080]' gst-launch-1.0 v4l2src device="/dev/video0" num-buffers=1 ! video/x-bayer, format=rggb, width=1920, height=1080 ! bayer2rgb ! imagefreeze ! kmssink driver-name=tidss plane-properties=s,zpos=1
Take and save image to image.jpg:¶
media-ctl --set-v4l2 '"imx219 1-0010":0[fmt:SRGGB8/1920x1080]'; ; media-ctl -d 0 --set-v4l2 ''\''cdns_csi2rx.30101000.csi-bridge'\'':0 [fmt:SRGGB8/1920x1080]'; media-ctl -d 0 --set-v4l2 ''\''30102000.ticsi2rx'\'':0 [fmt:SRGGB8/1920x1080]' gst-launch-1.0 v4l2src device="/dev/video0" num-buffers=1 ! video/x-bayer, format=rggb, width=1920, height=1080 ! bayer2rgb ! jpegenc ! filesink location=image.jpg
