Cortex-A53 Development
Development Environment
Docker Build Environment Information on installing and using the build environment within a Docker container
Code Composer Installation Information on installing and configuring Code Composer
gdb-multiarch Installation Information on installing gdb for multiple architectures
Linux User-Level App Development
Code Composer - C/C++ Project Information on building and debugging a Linux Application with a Code Composer C/C++ Project
Code Composer - CCS Project Information on building and debugging a Linux Application with a Code Composer CCS Project
Using Visual Studio Code Information on building and debugging a Linux Application using Visual Studio Code
Linux Filesystem
Building the filesystem Information on how to regenerate the reference filesystem using yocto
Customizing the yocto build Information on how to create a custom meta layer for your product
Linux Kernel
Building the Linux Kernel Information on how and why to build your own Linux Kernel
Debugging in the Linux Kernel Information on how to debug the Linux Kernel or a Kernel module
Setting up the Pinmux for Linux Information on how to setup the Pinmux
Building the PVR (GPU) Driver How to build the out-of-tree kernel driver for the AM62x GPU
U-Boot
Bootstrap process Description of the Bootstrap process
Building the MitySOM-AM62 U-Boot Information on how to build U-Boot for the MitySOM-AM62.
Debugging U-Boot Information on how to debug U-Boot
