This page provides links to MitySOM-AM62 specific software and prebuilt images to support using the MitySOM-AM62x development kit.
NOTE Make sure to "Watch" this page to get notified of updates
Source Code Repositories
The following are links to the repositories that Critical Link provides for the kernel, U-Boot, Yocto, and FPGA sample projects.
SDK 10.x scarthgap (AM62x/AM62Ax/AM62Px)
Type Repo Branch Notes
Kernel linux-kernel mitysom-linux-6.6.y Tracks TI's ti-linux-6.6.y
U-Boot u-boot mitysom-u-boot-2024.04 Tracks TI's uBoot implementation
Yocto Top Level / Setup oe-layersetup criticallink Adds Critical Link supplied Meta Layers to TI's PROCESSOR_SDK
Yocto Layer meta-mitysom scarthgap Critical Link SOM Support Recipes
Previous MDK releases...
Pre-Built SD-Card Images for the Development Kit
Note: The SD-Card Image requires a 16GB or larger Micro-SD card.
For flashing the Micro-SD card
MitySOM-AM62x Development Kit SD Card Image
The following is a link to the latest released pre-built binaries for the MitySOM-AM62x Development Kit SD card image for the SOM variants. It includes the complete A53 and R5 SPL and uBoot images as well as the root filesystem.
Description Location Manifest Based on TI Release Toolchain Release Notes
Reference Micro-SD card Image By default, this image is for HS SOMs tisdk-default-image-mitysom-am62x.rootfs-SDK10.01.10_28-20250220175550.img.zip md5 Manifest 10.01.10.04 gcc version 13.3.0 Release Notes
For GP SOMs, the same image can be used if tiboot3-am62x-gp-evm.bin is renamed to tiboot3.bin. If you use the image on a GP SOM without renaming the file, the target will not boot and there will be no output to the console.
MitySOM-AM62Ax Development Kit SD Card Image
The following is a link to the latest released pre-built binaries for the MitySOM-AM62Ax Development Kit SD card image. It includes the complete A53 and R5 SPL and uBoot images as well as the root filesystem.
Reference Micro-SD card Image tisdk-default-image-mitysom-am62ax.rootfs-SDK10.01.00_26-20250220173311.img.zip md5 Manifest 10.01.00.05 gcc version 13.3.0 Release Notes
tisdk-edgeai-image-mitysom-am62ax.rootfs-SDK10.01.00_26-20250220174616.img.zip md5 Manifest
MitySOM-AM62Px Development Kit SD Card Image
The following is a link to the latest released pre-built binaries for the MitySOM-AM62Px Development Kit SD card image for the SOM variants. It includes the complete A53 and R5 SPL and uBoot images as well as the root filesystem.
Reference Micro-SD card Image tisdk-default-image-mitysom-am62px.rootfs-SDK10.01.10_04-20250219224134.img.zip md5 Manifest 10.01.10.04 gcc version 13.3.0 Release Notes
Note: Images are built without chromium to reduce image size and greatly reduce build times. Several TI demos will not launch properly as such.
Previous SD card image releases...
Debian Image (Not typically needed)
In general, Critical Link recommends using the Yocto-based reference image for your development. TI, however, provides a Debian image as part of their Processor SDK . This image can be used with the MitySOM-AM62x devkit by:
  • Replacing the boot partition U-Boot files with files from the boot partition of our reference image.
  • Replacing the kernel files contained in the boot directory on the root partition with the corresponding files in our reference image.
  • Copying the Critical Link kernel modules from our reference image root parition (under /lib/modules) to /lib/modules.
The following table contains a direct link to a Debian SD card image for the TI AM62x EVM. This image assumes you are using a HS-FS processor.
See Updating the TI EVM Debian Image for the MitySOM-AM62x DevKit for commands to update the image to support the Critical Link MitySOM-AM62x DevKit hardware.
Description Location Based on TI Release
Reference Micro-SD card Image (DEBIAN) By default, this image is for HS-FS SOMs TI Debian Bookworm Processor SDK 10.0 (>700MB, A 16GB OR LARGER SD CARD is required) TI Processor SDK 10.0.07.04
Previous Debian release...
If you have any problems with this image or if you have questions about using Debian for your custom application, please contact Critical Link for further assistance or post in our forums.
Reference Toolchain Image
The following is a link to the Reference Linux Developer Toolchain based on TI's AM62x PROCESSOR-SDK-LINUX
MitySOM-62x
Reference Linux Developer Toolchain arago-2023.10-aarch64-linux-tisdk-mitysom-am62x-SDK10.01.10_28-20250220175550.sh md5 Manifest 10.01.10.04 gcc version 13.3
MitySOM-62Ax
Reference Linux Developer Toolchain arago-2023.10-aarch64-linux-tisdk-mitysom-am62ax-SDK10.01.00_26-20250220174616.sh md5 Manifest 10.01.00.05 gcc version 13.3
MitySOM-62Px
Reference Linux Developer Toolchain arago-2023.10-aarch64-linux-tisdk-mitysom-am62px-SDK10.01.10_04-20250219224134.sh md5 Manifest 10.01.10.04 gcc version 13.3
Previous toolchain releases...
Jailhouse Example Images
MitySOM-62x (2GB)
Base Jailhouse Example for MitySOM-62x DevKit tisdk-jailhouse-image-mitysom-am62x_2GB_10.00.07.04.rootfs.wic.xz 10.00.07.04
MitySOM-62Px (2 GB)
Base Jailhouse Example for MitySOM-62Px DevKit tisdk-jailhouse-image-mitysom-am62px_2GB_10.00.07.04.rootfs.wic.xz 10.00.07.04
Legacy Images
Legacy released images can be found at the following locations:
https://support.criticallink.com/files/mitysom62x/
https://support.criticallink.com/files/mitysom62Ax/
