DDR4 SODIMM Connector Information
The MitySOM-AM62 and MitySOM-AM62A edge connector interface conforms to the JEDEC MO-310, "260 PIN DDR4 SODIMM, 0.50MM PITCH OUTLINE", with the exception of the module height, which is 38.10mm instead of the specified 30.00mm. In addition, there is one component on the back side of the SOM that can be as tall as 1.75mm. Further detail can be found by downloading the appropriate SOM STEP model from this page.
The intent of the design is to support use with any SODIMM DDR4 connector conforming to JEDEC SO-O18, "260 PIN DDR4 SODIMM SOCKET OUTLINE, 0.5MM PITCH" with a mounted SOM height of at least 3mm between carrier board top and the center of the SOM PCB.
Validated Connectors
The table below lists connectors that have been validated with the MitySOM-AM62
Part Number Manufacturer Distributor Link SOM Height* (mm) Notes
2309409-1 TE Connectivity AMP Connectors Digikey 3.3 Used on MitySOM-AM62 Development Kit
*SOM Height is vertical distance from the center of the SOM PCB to the carrier card PCB surface.
Candidate Connectors
The table below lists connectors that should work with the MitySOM-AM62 but have not been validated by Critical Link.
Part Number Manufacturer Distributor Link (SOM) Height (mm) Notes
2309411-1 TE Connectivity AMP Connectors Digikey 6.1
2309412-1 TE Connectivity AMP Connectors Digikey 6.1
10141730-001RLF Amphenol ICC (FCI) Digikey 3.3
