Yocto SDK 08 Release Notes
  • 2023-02-24 - tisdk-default-image-mitysom-am62x_56.wic.xz
    Initial release. Support for the AM6254 GP modules
  • 2023-06-01 - tisdk-default-image-mitysom-am62x_79.img.zip
    Support added for the AM6254 HS modules
    Switch to processor-sdk-08.06.00-cl-config.txt
  • 2024-01-24 - tisdk-default-image-mitysom-am62x-SDK08-20240124151203_124.img.zip
    Support added for the AM6252/AM6251 HS modules
    Changes to u-boot and kernel to ensure 1.4Ghz cpu frequency waits for 0.85V VDD voltage increase.
    Improve DDR timings
    • Kernel changes:
      net: phy: micrel: ksz9131 led errata
      Merge remote-tracking branch 'ti/ti-linux-5.10.y' cicd.dunfell.202304260757
      serial: 8250_omap: Revert UART_RX_TIMEOUT_QUIRK
      mitysom-62x: Add aliases to allow u-boot to dynamically disable nodes based on cpu/gpu/dss/pruss presence
    • U-boot changes:
      mitysom-62x: Enable TPS65219 PMIC driver
      dts: Update to ddr config 09
      mitysom-62x: Sync device tree with kernel. Swaps usb0/1 for devkit Rev2
      mitysom-62x: dts: 2GB RAM: Update DDR timings to fix rare boot crash
      mitysom-62x: Add device tree fixup for CPU cores, GPU/PRUSS/DSS presence.
      mitysom-62x: Fall back to non boot_fit, if fitImage boot fails
